Switches without ground
Received 0 Votes
Why to some single pole switches have a grounding screw and some do not? Is there any problem using the switches that do not have a grounding screw?
The switches without a grounding screw may be the self-grounding type. These are designed for use in metal boxes and are grounded through the metal box.
If you are referring to older switches in existing circuits, then they were not required way back then to have a ground connection.
New switches must be grounded, either by a ground screw connection, or self grounding via the yolk to a metal box.
