Wiring a hot water heater
Old 12-19-05, 05:07 PM
B
Please advise what type of wire to run from the junction box to the hot water heater. Have 10/2 coming from the breaker to the junction box directly above the heater.
Old 12-19-05, 05:27 PM
HandyRon's Avatar
If that 10/2 is protected at the panel by a 2 pole 30A circuit breaker (or fuses), then 10/2 from the junction box to the heater.
Old 12-19-05, 05:31 PM
5
Your should probably use type MC or BX flexible armored cable for protection.
Old 12-19-05, 05:34 PM
B
Yes I have a 30 amp breaker. I thought there was a specific wire to run from junction box like 10/2 thnn or something like that
Old 12-19-05, 05:48 PM
ampz's Avatar
Us the 10/2 as recommended,armored cable is a good idea for added protection of the wires.
Old 12-19-05, 06:13 PM
C
I like these waterproof "whips". Makes for a very neat installation.
Are you putting any kind of shutoff at the waterheater? I installed a 30A double pole switch at mine so I can easily shut it off without a trip to the breaker box (other end of the house). If I had it to do over again, I'd use one of those disconnect boxes for AC units instead.
Old 12-19-05, 06:24 PM
B
I have seen the whips, but they seem to long. I only need about 3 or 4 feet to the heater. No cutoff, the main panel is only room away.
Old 12-20-05, 05:22 AM
T
In some areas it's required to have a switch within sight of the water heater. Also in some areas you have to "protect" the NM (I assume that's what you're using). I don't use NM in my area, so I have to use a piece of flexibly conduit.
Old 12-20-05, 05:23 AM
T
Also, the watertight whip can be cut if it's too long. I don't know how many AC installations I've seen where the installer thought it looks cool if the whip is 3 times longer then necessary. Perpahs they wanted it to "whip" in the wind.
Old 12-20-05, 10:10 AM
B
I found the right size whip in 6/2. I guess thats ok since I assume you can always go larger
Old 12-20-05, 12:19 PM
I
Received 45 Votes on 43 Posts
Yes, you can upsize to #6 wire however you need to get wire nuts rated for #6. I think Buchannan Grays or Blues Wingtwist are okay for a #6 to #10 splice; look closely at the wirenut packages in the store. They will have chart in fine print somewhere that lists the combinations of wire sizes for each size of wirenut.
