Dimmer For Aluninum Wire
Old 12-23-05, 02:59 PM
Has anyone heard of or know a source for a dimmer with aluminum wire contacts. Thanks and Happy Holidays.
Old 12-23-05, 04:47 PM
Use purple AL to CU wire nuts and copper pigtails.
Old 12-23-05, 07:02 PM
Thanks
But I really want the appropriate dimmer if available. The wire nut/pigtail has been studied and considered less safe. In fact it is less reliable than CO/ALR devices, and much worse than COP-ALUM crimps, which is second only to rewiring wth copper.
Old 12-24-05, 05:33 AM
Originally Posted by Capt
The wire nut/pigtail has been studied and considered less safe. In fact it is less reliable than CO/ALR devices...
I'm not sure that I agree with this. I have never seen this indicated before. Where did you read this?
Old 12-24-05, 06:31 AM
Ok
Check this for starters: www.alwirerepair.com/burned_purples.htm
Old 12-24-05, 09:20 AM
pcboss's Avatar
I can't remember ever having seen a dimmer rated for AL wire.
I have seen dimmers with temperature rating restricting the use on older wiring methods. I don't remember the temp tho. Even with the correct connection the wiring may not have the correct rating for the heat developed by the dimmer.
