Type of conduit
Old 12-27-05, 07:54 PM
Type of conduit
When installing a new hot water heater, does it matter if you use flexible metal, or plastic conduit to protect the cable. Thanks
Old 12-27-05, 09:18 PM
chandler's Avatar
Received 3 Votes on 3 Posts
type of conduit
It doesn't really matter, but it is alot easier to use a flexible whip from your junction box to the box on the water heater rather than a rigid conduit. You may want to check with your local inspector to see which one he requires, but I have never had a problem with 3/4" armored whip.
Oh, yeah, you can't heat hot water. Good luck.
Old 12-28-05, 10:26 AM
Sure you can, and must, to keep it hot.
A water heater with a storage tank uses energy to heat hot water all the time.
