change 1/2 switched outlets to all hot
i have a room where the entire circuit of outlets are(were) 1/2 switched. in the process of some wall modifications i did not hook switch hot feed to outlet.I want to get all oulets in circuit back to NOT switched. Can I jump the constant hot wire on the first outlet in the circuit to what was the switched (in my case the upper) outlet? if so will that convert all other top outlets to constant hot?
question re code
thanks for info. i will tackle this project over weekend.question, is it required to have a light or something controlled by the switch to assure that live wire isnt just hanging around or is there another reaon?
i will let you know how i make out.
