Vanity Light
Old 01-03-06, 12:13 PM
Vanity Light
I have a vanity mirror with lights that have a two prong plug and thumb on/off swith. I want to hard wire the lights to a wall toggle switch. After I took it apart there are only black and white wires, no ground wire. I understand this means self grounding (polarized) plug. Without grounding supply line from circuit breaker to the electric box in wall, how do you ground the lights, or do I need to?
Thanks
George P.
Old 01-03-06, 12:25 PM
Your vanity mirror is old, and was manufactured before grounded circuits were everywhere in a residence. As such, it is grandfathered and does not need to be grounded. However, it would be safer it it were grounded.
You can add a switch by running 14-2 cable from the light to the switch and wiring as normal for a switch.
Old 01-03-06, 12:40 PM
Vanity Light
Maybe I did not explain it right. This is a new mirror with light that I am installing over my vanity. The plug is two prong like alot of power tools are.
One prong is larger than the other prong.
Old 01-03-06, 12:42 PM
I don't understand your question.
Old 01-03-06, 01:18 PM
The OP wants to try to somehoe connect a cord an plug connected fixture to an ungrounded box.
IMO, a 2 prong outlet should be installed there. One should not hardware a cord and plug fixtured that was designed and approved as such.
Old 01-03-06, 09:04 PM
fixitron's Avatar
but if you do it anyway, use the same size cable as the rest of the circuit (ie, the power feed)(14/2 with a 15 amp breaker, 12/2 with a 20 amp breaker) and drill and screw in a short self-tapping screw onto the metal base of the light and secure the ground wire to it.
Old 01-04-06, 05:44 AM
Vanity Light
The power supply will be comming from a GFCI outlet. By grounding to the light, will this work and pass code?
Thanks very much
