Stripped screw receptical
Old 01-03-06, 03:04 PM
Binary Bob
Any tips on how to get the screws on a light switch to hold in a plastic receptical box?
The holes are stripped.
Thanks!
Old 01-03-06, 03:09 PM
Jam the hole full of toothpicks dipped in elmer's glue. When the glue sets up, trim the toothpicks flush with an utility knife, and use a sheet metal screw.
Old 01-03-06, 05:20 PM
Epoxy is also frequently recommended. Fill the hole with epoxy, let it dry, drill a new pilot hole, and reinstall the screw.
Old 10-01-09, 10:18 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
A bit of a hack but I have used coarse thread Sheetrock screws.
Old 10-01-09, 06:30 PM
Before you start useing tooth picks and glue and stuff like that, try to use a tri-tap and re-tap the threads, that way if it works it still looks clean and professional.
Old 10-04-09, 12:42 PM
Run a #8 tap in and use #8 screws.
