15 or 20 amp switch
Old 01-03-06, 06:47 PM
rdsatkaycee
15 or 20 amp switch
I'm installing basic bathroom vent fan. I am tying in to 20 amp circuit so using 12 gauge wire. But should I use a 15 or 20 amp switch for the fan? thank you
Old 01-03-06, 07:09 PM
Speedy Petey's Avatar
15a is fine. You only need a 20 if you are swithcing more than 15 amps.
A 15-amp switch is sufficient, but you can use a 20-amp switch if you want.
Depending on details not in evidence (like what else is on this circuit), this may violate electrical codes.
Old 01-04-06, 04:42 AM
rdsatkaycee
thanks Speedy and John. Because of price, I would rather not install the 20 amp switch, so I will stay with 15 amp white, thanks again.
Old 01-04-06, 06:18 AM
HandyRon's Avatar
rdsatkaycee,
I think what John was referring to was, whether your are tapping into the bathroom receptacle circuit? If you are, you can't.
Old 01-04-06, 06:19 AM
A
That depends.
Old 01-04-06, 06:29 AM
Everything depends.
Old 01-04-06, 06:38 AM
rdsatkaycee
I am tapping off of the main 20 amp line going in to the bathroom. The only thing that is on the switch is the vent fan
Old 01-04-06, 06:39 AM
R
What is important is what else is on this same circuit.
Old 01-04-06, 07:40 AM
HandyRon's Avatar
rdsatkaycee,
Unfortunately, to be code compliant, you cannot do as you plan. Find another circuit.
Old 01-04-06, 07:43 AM
R
Originally Posted by HandyRon
rdsatkaycee,
Slow down Ron. If this circuit serves only this bathroom then he can tap into the circuit.
