New Outlet
Old 01-06-06, 03:08 PM
New Outlet
I have 50amp GFI protected breaker going to an outside hot tub. I would like to put an additional 110 outlet in that location. It has two hot wires and a ground. Can I safely put an outlet just using one hot wire and basically using the ground as a neutral. Thanks! SB
Old 01-06-06, 03:10 PM
NO!!! Sorry...
Old 01-06-06, 03:35 PM
Not only can you not do this safely (for at least 3 major reasons), but the GFCI breaker will trip immediately as this is the sort of thing a GFCI is designed to protect against.
Old 01-06-06, 06:05 PM
Thank you!
