wireing a doorbell?
Old 01-07-06, 05:35 PM
wireing a doorbell?
hi,
anyone know about wiring a doorbell?
do transformers go bad?
i bought a new doorbell, but it still doesn't work. there's current that runs to it, and the switch works. the only other element in the circuit seems to be the transformer.
if i replace it will the doorbell work? its probably 20 years old. i think its 18v.
thanks,
max
Old 01-07-06, 05:52 PM
I bought a big bell that has a long string on it and it works great no wires no batteries just ring a ding ding
here is the link
http://www.mainegathering.com/bells.htm
Old 01-07-06, 06:10 PM
5
Transformers certainly go bad. Switches go bad more commonly. If you understand the wiring schematic of the circuit, troubleshooting is fairly straightforward.
Old 01-07-06, 06:23 PM
if i read your post correctly you have power as in 24 volt going to it and it doesnt work. did you buy a 120 volt bell. do you have 120v to the transformer. do you have 25 volts comming out of the transformer if you hook it up directly to the transformer do it work you may have bought a defective bell.
Old 01-07-06, 08:34 PM
G
Received 2 Votes on 2 Posts
You say that you have current running to the door bell. How did you test to find the current? Also, is it an actual bell or what is called a door chime and goes ding-dong. Please give us a little more to go on.
Old 01-08-06, 05:35 PM
i am trying to fix the "DOOR CHIME" the two toned bell.
i bought a 16v transformer to replace the old one (which was 16v too) and i also bought a volt meter.
the transformer seems to be working becuase the volt meter reads 17 volts.
do the door chimes usually need 24v?
i'm about to test the switch.
Old 01-08-06, 06:35 PM
G
16 volts should do it. Post back if you have further problems.
Old 01-08-06, 07:53 PM
Voltage isn't the only important specification of the transformer. You also need to check the "va" (volt-amp) rating. Different chime units need different number of va. A very simple chime (i.e., an $8 chime) needs about 10va. Two chimes need 20va. Some of the more deluxe chimes might need more. Make sure your transformer can supply the number of va that your chime(s) need.
