Weird outlet problem
Old 01-08-06, 05:41 PM
B
Question Weird outlet problem
I have an odd problem that developed on one circuit in a bedroom of my house. The lights that I had plugged in to different outlets would stop working using the switch on each cord. But, when I flicked the switch on either cord (each plugged into different outlets), it would turn off my alarm clock. Flick it again, the alarm clock turned back on. So I was getting at least some power....
Any leads to where this could have started or how to fix?
Old 01-08-06, 05:44 PM
R
You should start by checking each and every receptacle on the circuit.
Old 01-08-06, 05:47 PM
B
My father actually was in town and replaced each outlet to no avail.
Old 01-08-06, 05:50 PM
frhrwa's Avatar
sounds like there might be a wall switch to the outlets that is miswired in one of the electrical outlets?.. odd for sure.. don't think I've ever run across that one..
Old 01-08-06, 06:14 PM
R
My guess is that you have devices in serial, which is causing the problem.
