Quick question on ELEC COOKER installation
Old 01-09-06, 05:56 AM
Hi,
I have a quick question.
I have an electric cooker which has cable attached etc and is ready to be wired in to my mains.
I have the white box with the red cooker switch, my question is do i just wire it in here? Or does it need to be wired elsewhere?
Thanks (not very knowledgable on these things!)
Chris
Old 01-09-06, 06:05 AM
What white box?
Old 01-09-06, 07:11 AM
Hi sorry I just meant the socket with the cooker switch on it
Old 01-09-06, 07:18 AM
I still don;t know what you are talking about. Why don;t you specify the manufacturer and model number of the device, or better yet provide a link to the owner's manual on the Internet.
How this is wired depends 100 percent on the voltage and current requirements, and on where you live.
Old 01-09-06, 07:54 AM
I think he's talking about a slow cooker. All you have to do is plug it in and select your desired temp on the knob,low med high!
Old 01-09-06, 09:26 AM
Andrew's Avatar
From the terms used in your post, I'm betting you are not in the USA, but maybe in Great Britain?
Old 01-09-06, 11:01 PM
Yes, you wire your cooker into the cooker box, what else is it for, and what else would you connect the cooker to?
"Cooker" is UK speak for a kitchen range. They typically plug into or are hard wired into a switched/fused disconnect point, which is fed with its own breaker or fuse in the circuit panel (called a consumer unit in the UK).
