special purpose receptacles
Old 01-10-06, 12:22 PM
I have a 240v aircompressor in the garage that's on wheels. I'd like to be able to plug it in to any of 2 or 3 receptacles. Is there a code violation to parallel a number of 240v receptacles?
Old 01-10-06, 12:35 PM
SOP for equipment on wheels.
No code violation.
Old 01-11-06, 05:42 AM
BF: wilco and thanks for the quick reply.
Old 01-11-06, 05:09 PM
No code violation.
what is SOP.
cause i have a 50 amp breaker with one outlet.in my new garage and i tapped into that and extended that keeping the existing one. for using my 220 heater.
so that is ok. but i asked my nephew who is an electrician and he said as long as there are other terminals to attach the ongoing wires. but on mine there wasn;t so i had to piggy back them in the same screw clamp.
Old 01-11-06, 07:07 PM
davidmmm...
If that receptical for your 220 heater is anything other than a 50A receptical, you created a code violation...and I doubt your 220 heater uses a 50A receptical (if so, that's a warm garage!).
If I recall correctly:
15A recepticals can be fed by 15A or 20A* breakers
20A recepticals can ONLY be fed by 20A breakers
30A recepticals can ONLY be fed by 30A breakers
50A recepticals can be fed by 40A or 50A breakers
*A single 15A receptical must be fed by a 15A breaker, but a duplex, or multiple simplex 15A recepticals can be fed by a 20A breaker
This would not apply anywhere outside the USA.
Old 01-11-06, 07:20 PM
davidmmm, tell us your situation and we can tell you how to do this correctly. What you have done is not up to code and is unsafe.
You cannot extend a 50 amp 240 volt circuit to other size (amperage) receptacles. That's no good. You also cannot place more than one wire under a screw terminal.
Old 01-11-06, 11:17 PM
I thought you could only have one outlet on any circuit 30 amps and over. Or am I confusing this with some other rule?
Steve
Old 01-12-06, 11:20 AM
There is no such rule in general. It is, however, usually true for circuits feeding fixed appliances. But in this thread (well, at least in the first part of the thread before we launched off into the Neverland), we're not talking about a fixed appliance, so this is SOP (standard operating procedure).
Old 01-12-06, 09:23 PM
Huh. I wonder where I got that idea. I was pretty sure I read that somewhere. And it didn't have anything to do with fixed appliance circuits. Thanks for the info.
Steve
