switched receptacle problem
I replaced a switch and 4 receptacles in a bedroom. Everything works fine except the switched receptacle. I thought I followed the wiring correctly when I replaced the receptacles/switch but the switch is not working. I have power but the switch will not toggle the receptacle on/off correctly.
Any ideas?
Thanks!
Any ideas?
Thanks!
As XS6DFG0 has suggested, you probably forgot to break off the tab between the top half and bottom half of at least the receptacle that should be switched. Duplex receptacles have a small metal tab between the screw connections top half of the receptacle and the bottom half, on both the neutral and hot sides of the receptacle. When half a receptacle is switched and the other half is not then at least the tab on the hot (brass) side needs to be broken off. However, you also need to check the other receptacles, as they too need to exactly match the receptacles they replaced.
thanks for the assistance. I did remove the tab.. any other suggestions... i'm guessing I got two of the wires switched. what is the best way to troubleshoot?
Thanks!
My guess is that you removed too many or too few tabs, or the wrong tabs. The answer lies somewhere with the tabs. If you still have all the removed receptacles, it should be easy to check.
thanks!
Draw yourself a picture of where all the white and black wires go and where they are connected, top or bottom screw and if the tab connecting the top and bottom screws are there or missing. Then follow the flow of power from the source.
Well, I compared the old and the new and it appears that I removed the same tabs.
Answer Joes' questions that would help
