Is this possible? 2 circuits on one switch
Old 01-14-06, 09:36 AM
I have 3 basement lights on 1 circuit controlled by one light switch . So if the breaker goes- all my basemnt lights go out.
Is it possible to feed another circuit to one of these lights and have it controlled by the same light switch?
Old 01-14-06, 10:21 AM
Theoretically, you could use a 220V switch (one circuit on one side, the other on the other side). However, code mandates that circuit breakers feeding two circuits tied to the same yoke (the switch is a yoke) must have their handles tied so that if one trips, they both trip. Thus, you still have the breaker tripping leaving you totally in the dark.
Whats wrong with two switches in the same box? That would allow you to control the amount of light in the room.
Old 01-14-06, 11:07 AM
There is already a single lightswitch box drywalled in place. Was trying to avoid tearing open the wall to install a double lightswitch box.
All the lights and wiring to the lights are easily accessible tho.
Old 01-14-06, 11:19 AM
You don't have to tear apart the wall for the two gang box. You remove the old box, enlarge the hole, and install an "old work" box. These boxes have tabs that catch the back of the drywall to secure them in place without nails.
Before the old work box is installed, you will need to fish the additional cable(s) down to the opening for the second switch.
Old 01-14-06, 12:37 PM
double light switch, single box. switches operate horizontaly and a receptacle cover is used.
Old 01-14-06, 12:46 PM
pass & seymour # 696-wcc combination 1 pole, 3 way toggle switch-white
upc # 785007288841
cooper wiring devices # 271v-box (consumer package) same type
upc # 032664160400
they share a feed but you can break the tab to isolate
Old 01-14-06, 05:55 PM
If your breaker is tripping due to an overload, then you need to correct the situation that makes the breaker trip. Breakers should trip almost never. If yours is tripping more often than almost never, then you need to address that issue. Do not allow this to continue.
In the meantime, if being left in the dark is your concern, just buy one of those emergency lights that you plug in and comes on automatically when the power fails.
