220 to 110
Old 01-17-06, 09:43 AM
troyers
220 to 110
Maybe a stupid question, but can a 220 outlet be converted to 110? Our electric stove runs off 220. We are replacing it with a propane stove that requires a 110 outlet, but there isn't one available where it needs to be.
Old 01-17-06, 10:00 AM
Sometimes, and only sometimes, a 240 volt circuit can be converted to a 120 volt circuit. It depends on the wiring used for the 120 volt circuit.
Converting the circuit is not as easy or inexpensive as it sounds. If it can be done, you only save money on the wire itself. You still need to buy the appropriate breaker, you still need to buy the appropriate receptacle and junction box, and you still need to make the connections (something that is a little more challenging with the larger wire used for a 240 volt stove).
In my opinion, you would be better off running a new circuit and leaving the original circuit intact. Someday you might want to go back.
Old 01-17-06, 10:03 AM
troyers
Just happed to realize that the electric stove is probably hardwired. If we run a new new outlet, what do we do with the wiring that is left from the removal of the old stove? I'm assuming it'll be live, and I don't want 240 volt wires just hanging there.
Old 01-17-06, 10:06 AM
Cap the wires and put a blank cover on the box.
Old 01-17-06, 10:34 AM
Assuming is not allowed in this work. It should be on a dedicated breaker. Turn it off. And then you STILL cap the wires.
Old 01-17-06, 08:52 PM
fixitron's Avatar
Converting a 240 volt circuit to 120 volt is not difficult. If the wires and cable jacket are in good condition, and not aluminum, then you will need some large wire nuts and white tape. The cable should terminate in a 4x4 box (preferably deeper than 1" to accomodate the wire and outlet). Take the red (or black) wire and wrap it with white tape (to show that it is a neutral conductor) at both ends (the box and panel).
For the box (outlet) end: take a 6 to 8 inch piece of 12 or 14 gage white wire, strip 1/2-3/4" from one end and wire nut (a gray wire nut) to the wire with white tape. Do the same with a black piece of wire to the other large wire. Do the same with a piece of green or bare ground wire, wire nutted (a red wire nut) to the ground wire. Strip 1-1" from the other end of those pigtails and wire them to an outlet. Attach a 4x4 cover for single outlet to the outlet and screw the cover to the box.
In the panel, pigtail (with a gray wire nut) an appropriate length of white or black wire to the appropriate wire. The ground should already be attached to the grounding bar. Run the white pigtail to the neutral (grounded) bar. Attach the black wire to a 15 amp single pole circuit breaker.
If you do want to abandon a circuit, disconnect the wires from the breaker and cap off (with a wire nut) both ends of each of thos wires.
Maybe even put a tag on the cable to tell where it runs to, in case someone wants to go back to electric down the road.
Old 01-18-06, 06:43 AM
fixitron, your directions are functional, but unfortunately may be a code violation. Depending on the gauge of the wire, you usually can't just wrap white tape around a red wire and call it a neutral.
