load center
Old 01-17-06, 03:26 PM
load center
does anyone know where i can buy a 150 amp load center service rated with feed thru lugs with 2 breaker spaces
Old 01-17-06, 03:33 PM
hey gasfitter, i checked grainger but came up empty. can't jump from the old panel huh ?
Old 01-17-06, 03:40 PM
Speedy Petey's Avatar
This to me is a supply house item. If my guys don't have it they can order literally anything.
It can't be 200?? This is a pretty common item. I use them all the time.
150 stuff is getting hard to find. Very few are using 150 amp services anymore.
Old 01-17-06, 05:12 PM
yeah, 200 would work gasfitter, your just using it to jump to the 150 and feed a small double pole. a main disconnect would also be nice if possible.
Old 01-17-06, 05:22 PM
I just want to do it correctly. every electrician i talked to so far wants to do a line tap. I dont believe that is correct.
If i get a 200 with a feed thru and feed to the 150 would that be to nec code
Old 01-17-06, 05:30 PM
can't speak for code, but it makes sense. as long as the feed source is capable of the amp draw it should be ok. kinda like treating your switch panel as a sub panel. i'm just not at all comfortable with a line tap of any kind. if i remember correctly they want to tap at the meter. how would you shut that off ?
Old 01-17-06, 05:37 PM
just a thought. when i was living in a mobile home i had a main breaker outside. 200 amp in a nema 3 enclosure. whiy wouldn't that work as a feed to your switch panel? you could tap the 200 amp output with the 1 amp fuses to feed the utility terminals on the gen. killing the 200 breaker would also sumulate and outage to test the gen setup.
Old 01-17-06, 05:52 PM
You can have 200 amp service conductors, to a 200 amp meter, to a 200 amp feed-through panel, with feeders going to a 150 amp panel.
I am very fond of a "meter-main, feed-through" panel.
Old 01-17-06, 05:58 PM
<img src="http://s7ondemand1.scene7.com/is/servlet/izoom/DoItYourself/6767982?wid=200&hei=200&fmt=jpeg&qlt=75,0&op_sharpen=0&resMode=trilin&op_usm=0.0,0.0,0,0&iccEmbed=0">
http://doityourself.com/store/6767982.htm
Old 01-17-06, 07:04 PM
I guess i am doing my home work.
I am going to take pictures.
