Number of wires under one Nut?
Old 01-23-06, 05:07 PM
Iíve got an older bathroom with the ubiquitous junction box in the ceiling (accessed from the attic). One line in from the breaker feeds all the associated circuits, hence I had a couple of extra large (grey) wire nuts that tied together five 12g wires each (hot and neutral). This concerned me a bit because Iíve always stuck to a max of four per nut with 12g.
With a remodel I now have the need to tie in one more circuit; so thatís two 6 wire connections. Tying them 3 by 3 with a pigtail between sounds kind of silly, but what other configurations would work? My box is 4.75 x 4.75, so anything too fancy might get a little tight.
Is there another type of connector for this purpose?
Thanks for the help,
Stan
Old 01-23-06, 05:41 PM
hornetd's Avatar
Check the wire nut's rating
Check the capacity of the wire nut by looking at the list on the package. If the grey wire nut you have is a Buchanon B-cap B-4 it will connect 6 #12 wires quite safely. The grey buchanon wire nuts are listed for that combination of wires.
Tom Horne
Old 01-23-06, 07:41 PM
I have a similar circuit I'm setting up right now. I had found four sets of wires to be a pain in the other boxes, so I wanted to avoid doing a five wire box (1 in, 4 out). Instead, I was just going to do a three wire box (1 in, 2 out), with one of those going to a 4 wire box (1 in, 3 out). I figured this leaves room if I want to add another light, etc... Is this OK?
Old 01-24-06, 08:38 AM
Thanks
With the correct nuts - I'm gonna give it a shot.
