Sub Panel ground rod: Redundant?
Old 01-24-06, 10:12 AM
Since the main panel is grounded to Earth, is there a need to run a conductor from a sub panel, directly to a ground rod? Or, since the subpanel is already grounded to the main panel, which is already grounded to Earth, does this make a sub panel ground rod redundent, or, unnecessary, if you will?
Old 01-24-06, 10:50 AM
A sub panel in the the same structure as the main panel is not grounded via a ground rod.
A sub panel in a separate structure is grounded via a ground rod.
Old 01-25-06, 11:28 PM
bolide's Avatar
But please run 4 wires and do not bond neutral to ground.
If neutral is bonded to ground (three-wire feeder), the stray voltage effects are increased.
