Sizing Service Entrance Cable
Should I use 2-2-2 aluminum SE cable or 2-2-4 for a 100 amp service?
Frank
Frank
SE cable usage
First:[*]What is the relationship of the SE cable to your meter base,[*]Is there any overcurrent device before the SE cable,[*]Does this SE cable run thru any portion of your structure.
Frank
Frank
The NEC allows the neutral size to be reduced based on the maximum unbalance of the load between the neutral and either hot wire. By code this could be as small as a #8 on a 100 AMP service. But, unless you can calculate the unbalanced load go with the 2-2-2. Frequently a #4 is OK but sometimes a 3 will be required and this is no place to be guessing. Cost isn't an issue here.
UNK
UNK
I use 2-2-4 or 4/0-4/0-2/0, for 100 and 200 amps. It's all my supply house carries.
I've never had one complaint about computer "noise".
I myself have 4 computers and a LOT of electronic equipment, it's not a problem.
The physics behind high frequency conduction speaks for itself.
The larger the neutral the better noise is conducted back to the transformer.
As computers move toward making ever higher frequency noise, the larger neutral is even better.
50 years ago, who knew?
You can't go wrong with the larger neutral for many reasons.
Since when is the neutral the means of dumping high frequency noise? The ground and proper sheilding is the means for dumping most HF noise. In fact many commercial computer installations use 240 volt on-line UPSs to power computers precisely because it does away with neutral CAUSED noise problems.
UNK
UNK
The ground and proper shielding is the means for dumping most HF noise.
You can't go wrong with the larger neutral. Computer power supplies put noise on the grounded and ungrounded conductors.
The larger the diameter of these conductors, the better.
(The same holds for the grounding conductors too, and fortunately these are the same size as the other conductors in internal wiring. But this doesn't mitigate the noise from switching power supplies.)
Originally Posted by bolide
That doesn't mean that you aren't pushing the limit.
How is this "feedback" shown, seen or noticed.
Like I said, I see, and have never seen, any problems in ANY installation.
