Simple Fixture Grounding Question
Old 01-27-06, 11:46 AM
X
I have a black, white, and ground wire coming into a ceiling box. I have a light fixture with a black, white, and ground wire. If my ceiling box is plastic, I understand that both bare ground wires get twisted together with a wire nut and tucked into the box. I know this might be dumb, but what do you do if the ceiling box is metal with a green ground screw? Do you do the same thing as with a plastic box or does that green screw need to come into play somehow?
Thanks.
Old 01-27-06, 12:28 PM
bolide's Avatar
You wrap the ground wire (that comes from the switch) about 5" from the end of the wire around the green screw clockwise, tighten it, and proceed as with plastic.
Old 01-27-06, 01:13 PM
X
So basically I am still connecting the two ground wires with a wire nut, but I'm also looping the ground wire (that comes from the switch) around the green screw of the box.
Can you explain why this is done? What is there to gain by adding the metal box to the ground?
Thank you by the way.
Old 01-27-06, 01:18 PM
G
You would pigtail an additional wire and screw it to the metal box.
Some city's don't allow wrapping a ground wire around a screw then continuing to more wires.
Old 01-27-06, 01:23 PM
X
Again, why the need to incorporate the metal box into things?
I'm just wondering why it's done?
Old 01-27-06, 01:36 PM
G
Grounding the box prevents it from becoming hot if a hot wire gets loose in the box.
If someone opens the box with the power on you don't want the box hot.
Old 01-27-06, 01:58 PM
X
I see the logic.
Thank you.
