Plastic Boxes in Hot Attic?
Old 02-06-06, 07:54 PM
At the risk of starting another plastic/metal debate, I have a simple question. I'm replacing wiring and receptacles in the finished attic now, and I picked up some large plastic boxes because they are a little faster. Now, I'm wondering about this because it can get very hot up there in the summer--particularly if you aren't running any A/C up there. Will the heat cause the plastic boxes to soften and become deformed? Would it be better to use metal or the sturdier plastic boxes?
Old 02-06-06, 08:16 PM
bolide's Avatar
No, it doesn't get that hot.
But considering the ambient temperature, you should use #12 wire and limit circuits to 15A.
> Would it be better to use metal ... boxes?
Of course!
Old 02-06-06, 08:27 PM
Speedy Petey's Avatar
No.
Unless I need to bring a metallic whip or conduit out of a box, with NM I typically use NM boxes. I've NEVER(!!!) had a problem because of it and don't expect to ever have one.
Neither is safer.
And by all means neither is unsafe.
It's your choice though.
