High Voltage Reading
Hi all,
I'm upgrading light fixtures in my garage. The existing lights are operated by two, 3-way switches.
As part of the upgrade, I am moving one of the switches to a more convenient location. While doing the prep for the switch move, I took a voltage reading from the 12-3 wire supplying the switch from the breaker box at the switch itself. I took readings with the hot source both disconnected from and connected to the switch.
I was a bit surprised when the reading showed at 157 alone, and 153 when connected to the switch. I know voltage levels can vary by as much as 15 volts either way, but I have never seen this before.
Any ideas on what is causing the higher voltage? I checked other lines and none of them have the same high voltage reading.
Thanks!
Rick
Thanks!
Rick
Try a differant meter. If it still reads high call the power company. You don't go by volts on plus or minus. Voltage can vary + or - 10%. so at 120V, 132V would be the max.
Received 0 Votes
Use an analog meter and/or check the battery in your meter. A bad battery will lead to an incorrect reading.
you guys were right - the battery in my meter was going. A new battery fixed it.
Thanks guys!
Rick
Thanks guys!
Rick
Previous Thread
Next Thread
