Kitchen flourescents
Old 02-07-06, 10:30 AM
I would like to install (2) fluorescent fixtures to replace the single incandescent light that exists.They will be ceiling mounted above a luminous suspended ceiling,with each one being about 18-24" away from the existing ceiling box.
My question is that if I run a length of 14/2 cable from the box to each fixture what is the correct way(if any) to join/secure the wires at the ceiling box when the cables are run across the face of the ceiling drywall?
Thanks for any help and or suggestions.
Also...is the part of the fluorescent fixture under the ballast cover with all the wiring enclosed considered a "junction box"?
Old 02-07-06, 03:25 PM
bolide's Avatar
What amperage breaker protects this circuit?
The cables need to be stapled/strapped to the ceiling and within 12" of the junction box.
The cable must be clamped to the box with a NM cable box connector.
Yes.
Here also, the cable must be clamped to the fixture with a NM cable box connector in the hole where it enters the fixture.
Old 02-07-06, 05:28 PM
Thanks for the responses......
15A breaker..Is that not good?
Old 02-07-06, 05:41 PM
chandler's Avatar
No, Bolide was just making sure you were using the proper gauge wire on the proper circuit. A 14-2 cable is fine with the 15 amp breaker. If you had a 20 amp breaker, you would have to use 12-2.
Old 02-07-06, 05:54 PM
Thanks Larry...for the clarification.
The existing wiring is 12/2...from the 15A breaker.Should I use 12/2 instead of 14/2 from the existing JB to the fixtures?
Old 02-07-06, 06:01 PM
Yes, stay with your existing wire size - 12-2. Someone may see the 12-2 in panel and replace the 15A breaker with a 20A....
Old 02-07-06, 06:23 PM
Roger that Rodek01..thanks for the reminder.
Old 02-07-06, 07:57 PM
To add, they make round plates with a standard knockout in the middle, you will need one of them.
Old 02-07-06, 08:26 PM
Thanks classicsat.....I'll hunt down one of those tomorrow.
Thanks again everyone for the help.
