Outlet extensions?
Old 02-07-06, 02:13 PM
Outlet extensions?
I am remodeling a kitchen and installing backer board and tile for a added depth of 3/4 inch to the wall. What is the correct way to make the outlet and switch boxes line up with the new wall? Thanks. Also as this is in a kitchen do I need to replace the old outlets with GFCI outlets? GFI outlets
Old 02-07-06, 02:15 PM
You most likely need to bring the kitchen completely up to code. You at least need to bring the counter top receptacles up to code.
Either replace the boxes or use box extensions.
Old 02-07-06, 02:20 PM
Tom Bailey
How are box extensions installed? It looks like they are screwed intowall on top of old box?
Old 02-07-06, 02:22 PM
They make different types. The better ones screw on to the top of the box.
