What gage wire should I use?
Old 02-09-06, 02:26 AM
ih82w8's Avatar
Question What gage wire should I use?
So I have read and heard that for a 3 prong outlet you should use 12 gage not 14 gage wire. If this is the case though why do manufactures make most 3 prong outlets with quick connects that only accept 14 gage wire. So basically my question is should I use the 14 gage and if so then should I use the quick connects or would 12 gage and the side screws be a better way to go?
Thanks,
Old 02-09-06, 04:36 AM
bolide's Avatar
Originally Posted by ih82w8
So I have read and heard that for a 3-prong outlet you should use 12 gage not 14 gage wire.
Where did you read this?
Keep reading and you will learn that none of us uses the backstabs.
No. If you don't know when it can be used safely, do not use it at all.
No. The connectors that actually tighten and release by the screw are fine.
Otherwise, make a loop around the screw.
You can use an ear on the receptacle to build the loop. I use a Klein electrician's screwdriver.
Yes. Even better are spec grade receptacles that have a pressure clamp and do not require looping the wire at all.
Btw, they are better quality on the front too.
R
I don't know where you read this, but it's nonsense.
The wire size is determined by the over current protection, that is by the fuse or circuit breaker. 15 amp circuits require a minimum wire size of 14 gage. 20 amp circuits require a minimum wire size of 12 gage.
If you are installing a new circuit for general purpose use, then you can make it either a 15 amp or a 20 amp circuit. If the circuit is for a bathroom, kitchen counter top or laundry then it must be 20 amp. I would suggest only 20 amp circuits for receptacles, regardless of where they are located.
If you are extending a circuit then use the same size wire as the rest of the circuit.
Don't use the back stab quick connects. They have a tendency to fail over time and you end with an open circuit. Use thew screw terminals instead.
Old 02-09-06, 04:50 AM
K
Is it possible you confused the terminology? There is a receptacle with two vertical prongs and a horizontal prong perpendicular to the left vertical. Maybe someone referred to that as a 3 prong? That's a 20 amp receptacle and should only be used with 12 gauge wire, never 14 gauge.
