Adding new outlet for tv question.
Old 02-09-06, 10:54 AM
P
paradis2
I'm planning on wall mounting an LCD tv in my bedroom and want to keep everything clean. I want to add an outlet behind where the tv will hang. There is an existing outlet near the floor directly below where the tv will hang, and I believe that wiring runs up from that outlet towards the ceiling.
Would it make sense to splice into the existing wiring to add the new outlet? I'm not familiar with building codes, so please let me know if this is the wrong approach.
Thanks!
Old 02-09-06, 11:04 AM
R
Yes, it makes sense that you could tap into this receptacle, provided that the circuit is properly grounded.
However, it may or may not make sense to tap into the cable. Determine if in fact the cable does run up the wall.
Old 02-09-06, 11:23 AM
P
paradis2
If it does run up(I'm fairly certain it does, its an area between 2 closets) Is splicing the best option, or should I just run new wire from the lower outlet?
Thanks again for your help.
Old 02-09-06, 11:27 AM
R
Probably the better option would be to splice in the new box, which means you will have to replace the cable from the new box down to the existing box.
