Generator GFCI
Old 02-10-06, 05:39 AM
Cool Generator GFCI
The GFCI in my home generator trips when I connect to my homes electrical panel. If I don't connect the green ground wire in this connection everything is fine. Is there any reason why I should not run it this way ? I have connected the ground bar in the manual transfer switch to the ground bar in the main panel.
Old 02-10-06, 08:28 AM
That makes sense because the GFCI is sensing the bond between the neutral and ground in the main panel. I've never had to deal with that issue, so we'll have to wait for one of the other experts. Some of these guys install these generators for a living, so they'll let us know.
Old 02-10-06, 09:13 AM
bolide's Avatar
Originally Posted by ghivancich
The GFCI in my home generator trips when I connect to my home's electrical panel.
Was the generator made to be hooked to a panel?
Old 02-10-06, 07:40 PM
If your generator has a bonded neutral, then you will have the neutral and ground together at two points, the main panel and the generator. This would cause your GFCI to trip.
Old 01-28-07, 03:06 PM
Yes, there is a reason!
At the Briggs and Stratton web-site for generators they tell you that the GFCI generators are not intended or designed to be connected to the main panel, because the NEUTRAL bar and the ground bar are bonded together in the main panel and therefore DO NOT OPERATE as such! Removing the green ground wire creates a electrical safety hazard because it is the safety grounding wire! You might get a electrician to tell you how to bypass the GFCI on the generator so as to make it a conventional output without GFCI protection, BUT if someone at ever got shocked from such and spilled a hot cup of coffee in their crotch and they lived through it, someone would be liable for such! (the GFCI protection limits the amount of electrical shock to a safer limit for humans which is 7millamps or less of current through the body!)
Hope this helps you!
Old 01-28-07, 06:02 PM
How exactly do you have this connected to your house panel?
Why are you just useing the GFCI and not the 4-wire rec.? One is made for your use and the other (GFCI) is used for local purposes (drills etc.).
What size generator is it?
Old 01-28-07, 07:50 PM
Speedy Petey's Avatar
Guys, you realize this post is a year old, don't you.
Old 01-29-07, 04:38 AM
Speedy Petey
NO, I DID NOT SEE THAT IT'S A YEAR OLD! Maybe it might help someone else!
Thanks for pointing that out!
