Lighting on 15amp line only?
Old 02-11-06, 02:43 PM
I renovated my (dry) basement and ran a new 20 amp braker
and 12 gage wire to 6 - 20 amp outlets and interupted the line with a switch
to turn four wall sconces on and off. I read on the forum that lights must be on a 15 amp line. Do I have a problem?
Old 02-11-06, 02:54 PM
You heard wrong. Lights can be on a 20 amp circuit.
Old 02-11-06, 02:55 PM
hornetd's Avatar
No, it is perfectly acceptable to supply lighting fixtures (Luminaires) from a twenty ampere circuit.
Old 02-11-06, 04:34 PM
You don't list your location. If you live in Canada you heard correct. Lighting must be on 15 amp circuit.
Old 05-30-06, 11:29 PM
I am planning to do the same. Currently, I have 6 outlets on a 20 amp circuit in my basement and wanted to make one of the recepticles 'switched' as I do not have a mounted light fixture. My questions is:
Do I run the 12 gauge wire to the switch and light as well? Or do I use 14 gauge. I always notice the 15amp rating on the switches I've purchased.
Thanks-
martyc
Old 05-31-06, 03:36 AM
Speedy Petey's Avatar
It MUST remain all #12. The switch is rated for the load it is switching. As long as you are switching 15 amps or under you are fine.
Old 05-31-06, 02:03 PM
Thanks! I actually might modify two recepticles to be switched and I'll only have one lamp connected to each one. Each switch will be seeing less than an amp.
martyc
Old 05-31-06, 02:22 PM
lexmarks567's Avatar
hes in new york so its perfectly safe
Old 05-31-06, 02:59 PM
Who is?
Old 05-31-06, 04:13 PM
hornetd's Avatar
Did you let the magic smoke escape?
lexmarks567
Did you let the magic smoke escape from your monitor. You do know, I hope, that once the magic smoke escapes it generally cost a lot of money to put it back in so that the item will resume working.
Tom Horne
Old 06-03-06, 11:27 PM
Originally Posted by Speedy Petey
Who is?
BEBOB
You guys wanted to know if he was in USA or CANADA to see if he could use the kind of wire he wanted.
Old 06-03-06, 11:29 PM
Originally Posted by hornetd
lexmarks567
Tom Horne
