220 outlet
Old 02-12-06, 05:14 PM
220 outlet
when I had my house built I paid for a 220 outlet in the garage for my table saw. They installed an appliance receptical with 4 spades. My saw and other machines have only 3 spades. The wires in the receptical are red, black, white and a copper ground, so I have too many wires. I'm not all that familiar with 220 hook ups, can someone help.
Old 02-12-06, 05:32 PM
What size breaker did they use? What size cable did they use? You can simply change the receptacle to the proper one to match the breaker and cap the white. The neutral(white) is not needed in most 240 volt applications.
Old 02-12-06, 06:10 PM
Speedy Petey's Avatar
What Joe said.
Just stating 220 or 240 is only half the equasion. We need to know the amperage. If you simply asked for a "220 line" they mosy likely put in a line as big as they thought you might ever need.
If it is 4-prong then this is a 120/240 circuit, such as a dryer or range would use. Not much else though.
Good thing is this is most likely more than you would ever need for a table saw so you can downgrade the receptacle/circuit to meet the needs of the saw. You cannot usually "upgrade".
Old 02-12-06, 06:33 PM
30 amp breaker
The table saw draws 15 amps, the breaker is a 30, the cable is 12. If the receptacle was meant for an appliance then the white would be for 120 vac like for a light or clock on a stove? So I can cap it off and just use the black, Red and grnd?
Old 02-12-06, 07:12 PM
Exactly.
But do NOT use the 30 amp breaker. Use a 20 on that #12 wire.
There are codes for motors which let us upsize the breaker for a given wire size, but for a general 240v recpetacle in a garage you should not do this.
Old 06-19-07, 08:14 PM
220 outlet
the instruction on out box says white wire to silver screw and black and ground to two other screw but my wiring has just red black and grould is the red wire the one i would use instead of white
Old 06-19-07, 08:20 PM
220 outlet
the instruction on out box says white wire to silver screw and black and ground to two other screw but my wiring has just red black and grould is the red wire the one i would use instead of white this is for a range and the breaker box is 50 and the box i purchased is a 50 is this correct
Old 06-19-07, 08:25 PM
50 amp breaker
c breaker is a 50 amp and the 220 out box i purchased was 50 amp this is for a kitchen stove
Old 06-19-07, 10:17 PM
^ where did you come from and Please re-phrase your question or answear, it is rather incoherent.
