Previous Owners Used Outdoor Wiring Inside
Old 02-13-06, 10:42 AM
artieess's Avatar
I am in the process of adding a dimmer switch to control a chandelier (that's replacing a pull chain-control ceiling fan). The wiring comes from a standard recepticle through Wiremold then to the chandelier. I am going to add a dimmer between the recepticle and the chandelier. The old wiring is stamped "UL 14-2 AWG 14 Ground Type UF600V UV resistent". This seems like it's outdoor cable. Does that make sense?
Also, I am planning on replacing the existing run from the recepticle to the chandelier. I have 12-2 NM-B Romex. Can I use that or should I get 14-2 NM-B?
thanks
rts
Old 02-13-06, 11:12 AM
That is okay. They just wasted money using expensive UF cable where they could have used NM indoors.
You should use #14 if it is a 15A circuit or #12 if it is a 20A circuit. You can use #12 on a 15A circuit, but it will be confusing to someone down the road who might mistake the 15A circuit for a 20A circuit when he sees #12 wire.
It does not make sense to use UF cable inside wiremold. Wiremold is designed for individual conductors. But what's done is done.
Assuming this is a 15 amp circuit, I would use 14-2 NM-B from the receptacle to the switch and then NM-B 14=3 from the switch to the ceiling fixture. This is, if you intend to run the cable inside the walls/ceiling. If you plan on using the wiremold I would use individual 14 gage conductors.
Old 02-13-06, 03:13 PM
bolide's Avatar
But what's done is done. I think it is more confusing if there is a larger size in the panel and a section that is smaller somewhere else. When the panel is replaced, that circuit could end up with a 20A breaker.
I vote for maintaining the existing size throughout the circuit.
Old 02-14-06, 10:45 AM
artieess's Avatar
It is 15 amp. I will stay with 14 gage wire.
I am not clear about the difference b/t 14-2 and 14-3. Won't one of the conductors in 14-3 just go unused? I thought 14-2 would connect with black from recepticle to dimmer then black from dimmer to fixture; white would be uncut and go straight from recepticle to fixture; green/ground would connect from recepticle to fixture.
Also, racraft, are you recommending individual conductors because of an issue with fitting NM-B in the wiremold?
Thanks to all for the help!
Old 02-14-06, 11:15 AM
I am recommending 14-3 instead of 14-2 for future use. Someday you or someone else may want to put in a combination fan and light, in which case it will be better to have an extra conductor.
Running NM inside the wall and ceiling is my first choice recommendation.
I am recommending individual conductors if you keep and use the wire mold because that is what it is designed for. But this is my second choice recommendation.
