Wiring basement/recessed w/dimmer
Okay it's time to move on to the rest of the basement. The three way is installed and now I want to wire the recessed cans that I put in. I'll use power from an outlet I moved. Will some one please tell me the safest way to wire these? (and I mean step by step
) I am able to get the power to the first can. My inexperience told me to test with a regular switch as to not burn out the dimmer if my wires are crossed. So, the switch is in the off position, yet the light is on. When I hit the switch to on; the breaker cuts the power. Simple wire mix-up (I guess) Once I get the wires straight what is the best way to wire the rest of the cans? Any and all replies are welcome. Well maybe not the ones where a guy that knows what he is doing is cracking up!
basement wiring recessed w/dimmer
Okay, it's on to the rest of the basement. Please help me understand(step by step) what I'm doing wrong when I wire a regular switch to one of my recessed cans and the light is in the off position yet the light is on. When I turn the switch to the on position the breaker cuts the power. I'll hook up the dimmer once the wiring is straight. Once all is well; what is the best and safest way to wire the rest of the cans and the dimmer.
Received 0 Votes
Please buy and read at least one book on home wiring. The book Wiring Simplified is inexpensive, and you will learn much from it. There may be other mistakes you are making in addition to the one you have apparently made. Electricity is nothing to play with. It can and does kill people and start fires.
If you turn a switch on and the breaker trips, then you obviously have a neutral wires to the switch or you have a ground wire shorting.
A switch is used to break the hot side of the circuit. A typical setup will have power coming in to the switch on a cable. The black wire is the hot wire, and the white wire is the neutral. The bare wire is a ground and does not carry current during normal operation.
You will also have a single cable going out to the light. This cable also has a black wire, a white wire and a ground wire.
At the switch you connect the two black wires to the switch, one to each of the two non-green screw terminals. You connect the two white wires together with a wire nut. You connect the two bare ground wires together with a wire nut, and you also pigtail a ground wire to the switch and also to the box, if the box is metal.
If I were a betting man (I am not), I would bet that you connected the black wires to one "side" of the switch and the two white wires to the other "side" of the switch.
At the light, you connect the three wires (black, white, and ground) to the three wires for the light. The ground may not have a wire, it may have a ground screw that you connect the wire to.
To wire additional lights from this one, you simply connect your cable for the next light to the same three locations as the first wire.
There are other ways to wire a light switch, where you don't bring full power to the switch first, but rather bring it into the light. These methods are a little more confusing, so let's not go there if we don;t have to.
The three-way is installed
You should have black and white coming in. (Also grounds are always tied together, to the switch (and(/or) to the metal box)).
You should have red, black, and white going out either to the first light or to the other switch(es). You have to tell us the order in which the devices are to be connected, like 3-way, light, light, 3-way, or whatever.
In the first switch box, incoming white connects to outgoing white.
Incoming black connects to the black screw on the switch.
Outgoing red and black connect to the other two brass screw on the switch, one to each. (Black on the bottom, or red on the right depending on the layout of the switch. Doesn't matter too much except that I like all switches down to mean OFF.)
From the first light you need either 3-wire-plus-ground cable to the other switch and 2-wire-plus-ground cable to the next light in a deep box, or 4-wire-plus-ground cable to the next light.
Which way are you going to do it?
Received 0 Votes
If we have solved your problem, great, please let us know.
If we haven't solved your problem then please provide us more information, such as the exact details of how you have wired everything, so we can pinpoint the problem.
...betting man?...
...I'm glad your are not! I didn't even think to add the second line from the switch to the first can. I'll take heed to your warnings and suggestions. Here I go and I'll keep you posted. Thank you!
Wow, thank you ...
...gentlemen. How simple a task. Now I will run wire as needed for the other cans and I can prep for the dry wall. Again, thank you! Hey if you're ever consider visiting the Frankenmuth, Michigan area be sure to send me a message ahead of time; I'll show you around.
Gratefully,
Rob
Gratefully,
Rob
