speaker wire
speaker wire
Building a new house and I want to run speaker wire. Should I use some 16/2 or 16/4 for the runs? I am wiring to about 8 rooms.
Are you going to have volume controls in each room? Are you planning a centralized audio system? I would run a 4-conductor speaker wire (I prefer something a bit larger than 16AWG) from the central location to each volume control (home run rather than daisy-chain) and then a pair of 2-conductor wires from each volume control to each of the speakers associated with that volume control. Make sure you use speaker wire rated for in-wall use.
