max hole size in studs (framing members)
Old 02-21-06, 01:53 PM
Received 1 Vote on 1 Post
Here's one you other guys might know. The NEC only specifies that if a hole in a stud is within 1-1/4", you have to use an approved plate to prevent damage from nails, etc. But the NEC says that the maximum size of the hole is governed by other building codes. That makes sense, 'cause the plumbers and other wood-butchers have to make holes for some of their things, too. So, out of curiosity, what is a typical max hole size for a 2x4 stud versus a 2x6 stud? Obviously, AHDs will vary, but what might be typical?
Old 02-21-06, 02:16 PM
F
http://www.ci.chula-vista.ca.us/City_Services/Development_Services/Planning_Building/PDF/form_4592.pdf#search='max%20hole%20size%20and%20wood%20stud
Look at the table on page 4. I believe this is somewhat typical for most areas.
Old 02-21-06, 03:04 PM
Dead link. I even tried cut-and-paste...
Old 02-21-06, 03:11 PM
Received 94 Votes on 83 Posts
I couldn't get the link to work either.
Old 02-21-06, 03:31 PM
R
I have corrected the mistake in the URL.
Old 02-21-06, 03:52 PM
Thank you, that was the exact information I was looking for.
Old 02-21-06, 06:08 PM
L
ALOT of common sence! If you don't strucualy damage it. and when in doubt, Protect it.
