NEC Code for range wiring
Old 02-22-06, 10:46 AM
Were are in the process of installing a new duel fuel range. The information the the stove states that it has a 3.6KW / 240 rating and that 20amp 12 guage wire is okay. To be safe I ran 10/3 and was going to put it on a 30 amp 240 breaker. I was told that even though this maybe true, code requires that 8/3 needs to be run for ranges regardless if the stove draws that high of amps. Is this true? Idaho follow NEC.
Thanks,
Clay
Old 02-22-06, 12:05 PM
P
The requirement for conductors with an minimum ampacity of 40 applies only to ranges rated at 8-1/4 Kw or more.
Art210.19 (A) (3)
Old 02-22-06, 12:21 PM
bolide's Avatar
Originally Posted by store934
it has a 3.6KW / 240 rating and that 20amp 12 gauge wire is okay. To be safe I ran 10/3
Okay.
You need to use a 20A double-pole breaker.
Old 02-22-06, 12:38 PM
I
Received 43 Votes on 41 Posts
You must follow the Manufacturers' instructions to be compliant with the NEC; install a 20A breaker if the installation manual says to use a 20A.
Old 02-22-06, 02:12 PM
Okay, thanks for the help!
