Installing A Pull Chain On A Florescent Light
Old 02-23-06, 01:05 PM
L
Exclamation Installing A Pull Chain On A Florescent Light
I Have A Light Fixture With 2 Ballasts That I Want To Put A Pull Switch On... But I Keep Blowing My Circuit Breaker.... Need Some As To How To Wire....thanks
Old 02-23-06, 01:34 PM
R
The same as any other switch. Break the hot wire.
Old 02-23-06, 02:40 PM
L
Arrow
[QUOTE=LEOJANET]I Have A Light Fixture With 2 Ballasts That I Want To Put A Pull Switch On... But I Keep Blowing My Circuit Breaker.... Need Some As To How To Wire....thanks I CONNECT THE BLACK SWITCH WIRE TO THE BLACK POWER AND THE OTHER TO THE WHITE AND IT BLOWS THE CIRCUIT
Old 02-23-06, 02:56 PM
B
What you did will surely pop a circuit breaker. Leave the wire (neutral) alone. Cut the black wire connect it to one side of the switch and conection the other side of the switch to the other black wire, that you cut.
Old 02-23-06, 03:01 PM
G
Received 2 Votes on 2 Posts
Like Racraft said, cut the black power wire. Hook one side of the switch to each end of the black wire you just cut. You should end up with black wire-switch-black wire.
