Wire splicing
Old 02-23-06, 01:24 PM
Wire splicing
Can I splice 12 ga wire to exisiting 14 ga wire on a new 20 amp circuit?
Old 02-23-06, 01:30 PM
no way...this is a fire hazzard....if its a new 20 amp line the whole should be 12ga,there should be no 14 ga on it at all..how ever the 14ga got placed on a 20 amp line must be corrected immediately......14 ga is for 15 amps only.
Old 02-23-06, 01:36 PM
Thanks. The 14 ga is on a exisitng 15 amp line, but I am adding a new 20 amp line. I plan to move an existing light and switch that is on the 15 amp line to the 20 amp line. I will replace the 14 ga with ne 12 ga.
Old 02-23-06, 02:01 PM
To use a 20 amp breaker, the entire run MUST be 12 gage wire. There will be no 14 gage wire left when you are done.
Old 02-23-06, 07:41 PM
Nope. 14awg cannot be used on a 20A circuit. You can do this on a 15A circuit though. Just remember that the 12awg wire on that circuit is FOR that circuit, for future reference. It could be confusing if you see it later; you may think it's a 20A circuit.
