subpanel run from main
Old 02-24-06, 08:56 AM
want to run 100amp subpanel approximately 75 ft from main panel which is 200 amp
with 100 amp breaker for subpanel inside main panel
is #3 wire ok?
also, i got a verbal estimate of $400 or more for the job.
i can do this myself im sure as i have done electrical in and around my house over the years but im just curious as to if this is an over inflated price?
Old 02-24-06, 09:13 AM
bolide's Avatar
> is #3 wire ok?
Yes, if copper.
Get a written estimate.
That price is fine if the installer is knowledgable and proficient.
If you do it yourself, there are some easy mistakes to make, like you didn't mention what equipment grounding conductor you will use. Do you install the MBJ in the subpanel?
Old 02-24-06, 09:19 AM
T
off hand that sounds a little low. as bolide said make sure its in writing. does that include the sub and the breaker and labor. just the cost of the wire is high with the price of copper and building material in general so high. also an egc is needed to add to the expense. 75 ft of 3 #3's copper plus an egc, sub panel, breakers for main and sub. just be aware, sometimes too low of a price is sign of trouble.
Old 02-24-06, 02:33 PM
what an egc? is that the ground cable?
Old 02-24-06, 02:40 PM
When I do a subpanel, the price starts at $500 and goes from there.
Old 02-24-06, 05:31 PM
Old 02-24-06, 06:20 PM
R
Google is your friend.
egc: equipment grounding conductor
