blown light bulbs
Old 02-25-06, 12:51 PM
elocm2121
blown light bulbs
hello all,
I've recently noticed that my entire house tends to blow light bulbs like crazy, is there a simple test that can be preformed to find out if there is a problem with my electrical system.
Old 02-25-06, 01:51 PM
chandler's Avatar
Received 6 Votes on 6 Posts
With a voltage meter, test the incoming voltage at a receptacle. It should be between 110 and 125 in the US. Higher than that may cause blown bulbs. If it is high, contact your power company and/or install rough use bulbs rated at 130 volts.
