20 amp Outlets
Old 02-25-06, 05:44 PM
H
20 amp Outlets
I just added a garage addition to my home. This garage was wired by a licensed electrician for 20 amp. The wire he pulled was orange and the breaker is 20 amp. When he came back and finished the job he installed 15 amp outlets. I checked my kitchen outlets that were installed 20 years ago and they are also 15 amp outlets on a 20 amp circuit. I am not an electrician. Is this proper or was the electrician trying to save himself money on supplies?
Old 02-25-06, 05:53 PM
R
15 amp receptacles are legal on a 20 amp circuit in the US.
By the way, cable color means nothing. There is no standard.
Old 02-25-06, 05:54 PM
H
Thank you
Thank you for your reply.
Old 02-25-06, 06:04 PM
H
Question
Why would anyone spend the extra money for 20 amp outlets if 15 amp work as well.
Old 02-25-06, 06:36 PM
TomZ1's Avatar
You can't plug a true 20 amp appliance into a 15 amp outlet...note the "sideways" prong of the outlet on a 20 amp appliance.
Old 02-25-06, 06:42 PM
Speedy Petey's Avatar
When was the last time you saw anything in a home, other than an air conditioner, that had a 20a/125v plug on it.
Old 02-25-06, 07:57 PM
L
15 A rec. are legal if there is more than 1 rec IE: duplex rec.
However a single rec. on a 20a ckt must be 20A IE: twist lock, etc.
