AFCI in an older house
Old 02-26-06, 01:02 PM
L
Hi there, Need some oppinions.
In an older house, 1960, wired to code for the period. If I add some convenience rec. to the bedrooms, Must they, or the entire bedrm. be AFCI?
If AFCI required, then what must I do with the existing power ckts.?
Thanx.
Old 02-26-06, 01:32 PM
R
Ask the inspector. He or she is the one to make the call. The answer is most likely yes, assuming your area requires AFCI breakers.
Old 02-26-06, 01:53 PM
bolide's Avatar
Originally Posted by lectriclee
Need some opinions.
Opinions you shall get.
They must.
Whether the entire bedroom must be, in my thinking, is dependent on whether you are renovating or just adding some outlets.
If what you are doing presents an opportunity to upgrade the whole room, I don't know why you wouldn't.
Can you explain?
You just replace the existing breaker with an AFCI.
That's why it's hard to argue that this is too difficult, expensive, or inconvenient.
Old 02-26-06, 02:36 PM
L
Hello, The question why not? as you know there weren't many appliances in the early 60s. So some of the outlets are for other areas. I would love to rewire,(not my buget).I will go to the AHJ and see.Since there will be a permit for other work on the property.
It's one of those areas, no additions going on. non structual changes, etc. Just CYA, so I can keep my house.
Old 02-26-06, 04:37 PM
bolide's Avatar
Why re-wire? Just change the breaker.
Old 02-26-06, 05:43 PM
Speedy Petey's Avatar
Are AFCIs even required in your area?
If so then anything you install in BR's would require them.
Will the existing panel even accept them? You may need a panel change or service upgrade.
Old 02-26-06, 10:54 PM
T
Did the price on AFCI breakers go down? I know it isn't a fortune, and many will say it's a miniscule fraction of the cost of a life or a house, but $35 a pop isn't exactly cheap.
Old 02-26-06, 11:48 PM
bolide's Avatar
I guess so. I think it's been several years since I paid $35, even for Cutler-Hammer BRs.
