Dryer circuit
Old 03-01-06, 02:53 PM
Dryer circuit
I live in an old house (1876) that has a 100 amp panel. My dryer circuit has a 40 amp breaker. I have used it for quite some time. Recently I saw that my dryer is supposed to have a 30 amp supply. Should I replace my breaker? Can I just swap out the 40 for the 30? My supply cable runs into a 3 prong outlet.
Old 03-01-06, 03:43 PM
hornetd's Avatar
Check The Wire Size!
If the wire to that outlet is #10 CU or #8 Al or larger then you can just change out the breaker. Larger wire is fine but smaller than that and you will have to run new wire. I suspect that if it were smaller than that you would have made the aquaintance of your nearest fire stations crew by now.
Old 03-01-06, 03:57 PM
Thanks Tom! I appreciate the info. Not sure of the size. It is braided cable about the diameter of a thn pencil.
Old 03-01-06, 04:31 PM
bolide's Avatar
> It is braided cable about the diameter of a thin pencil
Sounds like #8 stranded.
That is large enough for the breaker. But the breaker is oversized for a clothes dryer.
Presumably you have a 30A receptacle.
Yes, you should have a 30A breaker. Is having a 40A likely to result in a visit from the fire dept? I don't see why.
