hooking up new cooktop
Old 03-05-06, 11:36 AM
My existing stove plugs into a 220 outlet that is mounted to the outside of the wall. The stove is being replaced by a jennair cooktop that has flexible MC coming out of it. Apparently, it has to be hardwired. My question is what is the proper way to connect the MC to the existing 220 outlet?
Thanks,
Josh
Old 03-05-06, 01:50 PM
chandler's Avatar
4" square junction box with correct strain reliefs, properly sized b-caps, or connectors,and cover, all mounted on the wall.
Old 03-05-06, 01:53 PM
are you saying to get rid of the outlet, replace it with a junction box, and connect the wires? Do you use wire nuts for wire this large?
Old 03-05-06, 06:02 PM
chandler's Avatar
The unit you are installing will be fixed in place and will not be pulled out to clean behind, etc. like a regular range, right? If so, it ceases to be a cord and plug situation, and should be hardwired. WingNut 454 will handle up to 2 #6 wires, and you probably only have #8 running to the receptacle.
