bathfan
Received 0 Votes
bathfan
Hello electrical masters
When I turn off my bathroom fan , the portable 1800W heater in my room connected to the bathroom shuts off sometimes [trips the gfci button to off] .This has a GFCI on the plug not the outlet . Are these on the same circut . Any idea what can cause this? Do i have an overloaded circut? And why would that outlet be on the same circut as the bathroom fan switch. Also I notice the bedroom light flickers sometimes.This all just started doing these things after i put a portable heater in this room.
Thanks all
Thanks all
Received 0 Votes
What do you mean it cuts the heater off? Do you mean that the receptacle the heater is plugged into loses power, and that when you turn the fan back off the power returns? Do you mean that the circuit breaker trips? Do you mean that the GFCI receptacle trips? Or do you mean something else?
Received 0 Votes
Bob, I don't think he's talking about a GFCI receptacle.
Sometimes fan motors create conditions that fool the GFCI circuitry, especially older GFCI circuitry. If the receptacle is already GFCI protected (and it shoud be), then you don't need the GFCI on the heater. You could just buy a space heater without an integrated GFCI.
Or you could just stop using the fan and the space heater at the same time.
