Lighting for above indoor pool
I am putting in a 12x19 wave pool and will be hanging lights from above. Does anyone know where I might find regulations about what type of light, shielding, wattage, unbreakable...etc?
I live in Michigan if that makes a difference to the coding.
The NEC is your guide. Sometimes other groups or organizations may put out pamphlets that specify rules for special situations, such as pools. However, make sure any of these other materials are not out of date.
Better yet, run the plan by the electrical inspector. Since they will be inspecting the work when it is complete, you want it right anyway. And if your thinking of not having the work inspected, think again. Electricity and water are not a good combination. If you do something wrong and it causes someone to be killed, you will be charged with manslaughter. Have your work inspected.
As long as the fixtures are totally enclosed, and the WHOLE circuit is GFCI protected, they can be 7.5' or higher above the water. This is for indoor installations.
