Long distance electrical run
Old 03-10-06, 02:19 AM
R
Installing a plug receptacle near my front yard for holiday lighting. The run will be a 20A, GFI circuit and is about 100' from the panel to the location. The wire will be thru 3/4" pvc conduit.
Is 12 gauge good or should I go to 10 gauge?
Old 03-10-06, 03:13 AM
bolide's Avatar
12 AWG is good. How many amps (or watts) do you actually need?
If more than 15A, your money would be better spent going multi-wire with a 15A double-pole GFCI breaker and 14 AWG.
Have you considered how you will control the circuit with a snap switch or timer?
Old 03-10-06, 06:10 AM
HandyRon's Avatar
For a long exterior run circuit, I would suggest placing the GFCI protection at the receptacle and not at the breaker. It reduces false tripping and offers you a more convenient location to reset the GFCI.
I agree that #12 is fine.
Old 03-10-06, 06:58 AM
R
Is the entire run in conduit, or only the outdoor portion? Make sure you use water rated wire outside (THWN).
Old 03-11-06, 02:23 AM
R
Hard to say. It will mainly be used for christmas mini lights and they don't say how many watts or amps they use. Only that they need a 2,5v and/or a 3.5v lamp, 150 in a set. I can't imagine it being more than a couple hundred watts, if that much.
I don't have many circuits left in my panel so I need to keep it to just one circuit. I already have a spare 20A breaker that I was going to use.
Probably just an electronic timer.
Exactly what I had in mind. Thanks Ron.
Entire run will be in conduit. Thanks for the tip on the THWN. I will make sure it has that rating.
Thanks guys. I appreciate the advice.
Randy
