GFCI and reverse polarity?
Received 0 Votes
We are trying to replace a working switch with a GFCI receptable. The switch is working at the beginning of the operation. We removed the switch and connected the black wire to the hot (brass) terminal of the receptable line and the white wire to the white (silver) terminal of the receptable line. And taa daa... nothing.
We've done this in other parts of the house had no problems.
Could it be a problem of reverse polarity? If so, how can we remedy to the problem.
We are a bit new at do-it-yourself project and will appreciate any help we can get.
Marie and Eric
Marie and Eric
Received 0 Votes
reverse polarity has nothing to do with it. a switch and a gfci are two different devices. a switch is wired with a hot and switch leg. a gfi requires a hot and neutral.
"We've done this in other parts of the house had no problems."
i dont see how this is possible. how many other wires in the switch box, if any? what was this switch controlling when it was hooked up? hold off on any other electrical projects until you read thru a basic wiring book.
Received 0 Votes
Hello Tach
Thanks for the quick feedback. Actually, we misspoke before. We replaced old receptables with new GFCI's. And this worked.
In the current situation, we are trying to replace a switch by a GFCI. From what you are saying, this is not possible.
If we want additional receptables in the room, we would have to draw the wires from another receptable outlet, right?
Thanks again,
Marie and Eric
Thanks again,
Marie and Eric
Received 0 Votes
We are working in the basement, but there is a wet bar in the area. We felt more comfortable using GFCI's. In any case, your feedback really helps. We'll draw the wire from another receptable. Thanks again.
Marie and Eric
Marie and Eric
