240 volt wiring/breaker
Old 03-12-06, 05:03 PM
i recently purchased a 240 volt wall heater, 1500 watts. im having a difficult time understanding the wiring aspect of it..
if i read correctly, do i have to use 12/3 wire and a 240 volt breaker which is a double pole breaker?
i had it temporarily wired to a 12/2 wire with a 20 amp breaker and it seemed to work very faintly, making me think thats because it only has half the power coming to it?
Old 03-12-06, 05:22 PM
You need 12/2 wiring and a 240 volt breaker. 12/3 wiring would give you a neutral that you would not need.
Connect the black and white wires to the breaker and the ground to the ground buss.
Old 03-13-06, 12:34 PM
ok, i'll go purchase a 240 vlt breaker and let you know how it turns out. thanks alot!!!
