15 amp outlet on 20 amp breaker
Old 03-20-06, 06:02 PM
jhowman
I have in my house a few outlets that are 15 amp rated but the service panel has 20 amp breakers for those circuits. Is this a problem? Do I need to install 20 amp outlets or switch the breaker to 15 amp service? Or should I be more concerned with the gauge of the wiring going to these outlets? I have not checked the gauge yet, but what would the smallest wire gauge that I could use for a 20 amp circuit?
Thanks for any help.
Old 03-20-06, 06:45 PM
chandler's Avatar
Received 6 Votes on 6 Posts
12 gauge wire for 20 amp circuit. The 15 amp outlets are fine as long as there are more than one on the same cable.
Old 03-20-06, 10:35 PM
L
A DUPLEX receptical counts as "more than one". So YES a 15 amp receptical on a 20 amp ckt is ok.
Old 03-21-06, 06:57 AM
K
Just for my own education, why would you need more than one receptacle?
Old 03-21-06, 07:05 AM
R
The short answer is because that's what required by the code.
The long answer is because it's assumed that a single receptacle on a circuit means that the circuit is in place for one load, and one load only, and that the size of the circuit is dictated by the load.
Old 03-21-06, 11:58 AM
I
Received 44 Votes on 42 Posts
This is allowed in the U.S. If you are in Canada, then 20A receptacles on 20A circuits are required.
Old 03-21-06, 12:03 PM
Received 383 Votes on 339 Posts
There are also local codes that prohibit using 15 amp devices on a 20 amp circuit. Depends on where you live.
