Emergency shutoff
Old 03-23-06, 03:44 PM
Emergency shutoff
Im not sure if this question goes under Elect or Plumbing/Heating... Where can the emergency shutoff switch for the furnace go...Mine is right next to the unit...Does it also have to be at the top of the stairs if the unit is in the basement.
Thanks
Tearflop
Old 03-23-06, 05:06 PM
bolide's Avatar
In an emergency, where do you want to go to shut off your furnace?
Old 03-23-06, 06:20 PM
in some states if you have oil burner furance system you have to add a emercy shut off switch on stairway to act like remote shut off but gaz fired unit hard to say but most place genrally say near the furance useally do the trick.
i am not sure where you from but i will suggest to check with building inspector they have latest code to deal with it
Merci , Marc
Old 03-23-06, 06:41 PM
Ok...thanks for the responses
Tearflop
